Timing values for 32B???
Old Sep 15, 2004 | 11:27 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Hi, I need to know in which table or tables do I adjust the timing at load values above 208? My IROC gets all kinds of timing retard because my chip has way too much timing at WOT. I would like to back off the timing so that hopefully I will avoid getting the knock counts and to eliminate the retard. I tried to modify the Timing Table at WOT but I do not see the load values that I need to modify, the table maxs out at 208, my load values are between 230 and 250 when the car is getting like 37-40 degress of timing. I need some help ASAP, TIA.
P.S. I did not add all the timing to the chip so it's not like I can reverse what I did before, I am strating off with a somewhat tuned chip, I just need to back the timing off.
Old Sep 15, 2004 | 11:37 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
- lower the value SA vs rpm vs load in the 208 "load column" or
- lower the SA in WOT vs RPM table (start adress187) not sure whats its name are in other programs.....
I'm using CATS....
/N.
Old Sep 15, 2004 | 11:40 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
I am using CATS so the start address it a bit unclear, like I said the SA in WOT vs RPM table does not have the load values above 208 - is there a multiplier I have to reduce? I do not see an extension table like there are for SD cars. I will take a look into the other table as well, thank you for your information
Old Sep 16, 2004 | 12:46 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
TTT
z28_AJ
Aug 27, 2015 08:59 PM
neekolzun
Aug 24, 2015 04:59 PM
ezobens
Aug 19, 2015 10:29 PM
tmellott89
Aug 16, 2015 02:58 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
