supercharging and prom settings
Old Sep 23, 2004 | 10:59 AM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
'87 350 TPI GTA modded. I was going to add an ATI procharger next year and I do make my own chips. Can anyone tell what needs to be altered in the prom settings, ie.MAF tables, when installing a supercharger.
The engine is already modified to accomodate a SC so I'm only interested in the PROM settings needed to run a SC.
Thanks,
Chris
Old Sep 23, 2004 | 02:25 PM
92GTA's Avatar
So are you planning on using the FMU or modding a stock ECM and PROM to control fuel under boost?
Old Sep 23, 2004 | 03:22 PM
sparks454's Avatar
Car: 1987 GTA
I am not planning on running a FMU. I am also running the Crane HI-6S which has boost retard capabilities.
Old Sep 23, 2004 | 07:39 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: supercharging and prom settings
S/C, and T/C put alot of heat into the intake charge when they compress the air to make boost. The 3rd Gen MAF system doesn't allow for ANY corrections for timing or fuel due to charge temp increases. So you wind up having to run the timing at worse case scenario settings.
Lots of threads here about the 749 which is what GM used in the Turbo charged Syclones. It has the proper tables, and code to deal with boost.
Old Sep 23, 2004 | 08:22 PM
JPrevost's Avatar
Car: 91 Red Sled
7749 :lala:
Old Sep 24, 2004 | 06:45 AM
sparks454's Avatar
Car: 1987 GTA
Does that mean another ECM or just a different bin?? Also, does this mean that with the 165 ecm I have to run the timing backed down a lot or is it just advantageous to convert to the 749???
Also, If I did run a FMU would it prevent me changing the ecm over to the 749??
Old Sep 24, 2004 | 07:37 PM
JPrevost's Avatar
Car: 91 Red Sled
It's a different ecm. One that was designed to run with a 2 bar map sensor. The code is better (my opinion) than the 165 as grumpy has pointed out countless times.
Steven 86IROC-Z
Today 12:59 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
