2 Bar and 3 Bar MAP Sensor P/N's???
Old Sep 23, 2004 | 11:26 PM
92GTA's Avatar
I thought I had the correct P/N for the 2 Bar but I just went to order it on GMPartsDirect.com and it's not listed there at all anymore:
2 Bar: 16254539
Odd thing though the weatherpack harness connector was still listed.
Anyway, does anybody have a "good" P/N for the 2 & 3 Bar MAP sensors? I mentioned the 3 because I may be going to that after the 2 and it would be nice to have the P/N handy....
Thanks!
Old Sep 24, 2004 | 05:17 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
2 Bar 16254539
3 Bar 16040749
According to Doc.
Old Sep 24, 2004 | 05:23 PM
92GTA's Avatar
The 2 Bar # 16254539 still is not good, there must be a new one now...
Also the new 3 Bar P/N is 12223861
Both use the same harness connector 15305891
Old Sep 24, 2004 | 05:47 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
GM PART # 12223861
CATEGORY: Computer Control Sensors
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $105.49
OUR PRICE: $52.75
DESCRIPTION: SENSOR AS
The old 16040749 part number has changed to this 2nd design and will require using a new connector 15305891 when replacing the first design sensor with the new 2nd design map sensor
If you are installing this on a vehicle other than a 1989 turbo T/A there will not be a warranty on this part.
Ouch... BW
Old Sep 24, 2004 | 05:49 PM
92GTA's Avatar
Originally posted by SATURN5
GM PART # 12223861
GM LIST: $105.49
OUR PRICE: $52.75
That's the new 3 Bar but I still need the new P/N for the 2 Bar which I'm sure others here will need sooner or later also...
Old Sep 24, 2004 | 05:56 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Auto Zombie and Disadvance both have 2 Bar sensors. Search 1990 Sunbird Turbo.
No luck with the GM numbers either. BW
EDIT:
Cool.... MAP sensor catalog with OEM numbers..
http://www.tomco-inc.com/Catalog/33map%20sensors.pdf
Old Sep 24, 2004 | 06:36 PM
89C2500's Avatar
Car: 89 C2500
Engine: ZZ838, MPFI, Whipple, & 7749 ECU
Axle/Gears: 4.10
New GM 2-Bar MAP #12569241 or ACDelco #213-1520
I know these are correct #s as I ordered this part recently.
Hope this helps!
J-money
Jan 4, 2019 09:45 AM
customblackbird
Oct 1, 2015 04:30 PM
87camaro87
Sep 9, 2015 10:29 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
greenyone
Sep 2, 2015 03:39 PM
