Spark retard issue
Old Sep 26, 2004 | 01:52 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Spark retard issue
I have MAF setup and am having trouble with spark retard. Installed new shortie headers. I disconnected the knock sensor and am still getting spark retard at throttle. Sometimes up to 12*. What else could cause this if not the knock sensor? Could it be a bad MAF? It seems with some datalogging that when throttle is applied the maf readings go up and so does the spark retard. They seem to be related somehow.
Old Sep 26, 2004 | 04:28 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Did you set a resitor instead of the KS?
Try to remove the 10kOhm from Pin B on the ALDL cable and see whats happen...
/N.
Old Sep 26, 2004 | 12:42 PM
/N.
No comprende amigo....I just unplugged the KS. How would I remove the 10kOhm form Pin B?
Cornholio7979
Sep 20, 2018 02:31 AM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
destroyerwes
Aug 26, 2015 08:17 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
