innovated LM-1 question
Car: camaro
Engine: 355 w/supercharger
Transmission: 700 R4
For those of you with the LM-1 I have a question. Can it datalog other inputs just with the base unit or do you have to buy the $250 aux box thing?
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
There's a $99 analog input box (or cable I think it's called) too. There's also an RPM pickup that you can clip over a spark plug wire - a few bucks more - $20 I think. But, I don't think you need that - I think you can hook a wire into the either the EST, REF, or Tach signal, or maybe even the Coil itself - just ask Innovate on that one.
I built my own interface to the LM-1. I used voltage to frequency converter IC's to interface RPM and MPH. I used the reluctor signals from the VSS and ESC module to the PCM. I then just tapped into the TPS, CTS and MAP sensors, referenced it to the LM-1 5V and common and put it on a project PCB and box from Rat Shack, connected it to a 7-pin Mini Din connector. After programming the inputs of the LM-1, it works great. It cost me about $25 in parts and a couple hours work. If you can follow a schematic and solder, it is a small project. I would be willing to share it if anyone is interested.
Car: camaro
HaulinA$$,
Would you by chance have the part numbers and where you got for the potentiometers you used in these. I am assuming they must be the smaller ones that you use a screwdriver on since I cannot really see them in the picture you have of it.
Thanks again
Thanks again
Originally posted by 67 ss
HaulinA$$,
Thanks again
HaulinA$$,
Thanks again
Digi-Key P.N., Desc., Price
490-2377-ND Trimmer pot, 20K, 12 turn $1.14
490-2378-ND Trimmer pot, 200K, 12 turn $1.14
You can get them at http://www.digikey.com
one more copy? laiky@aol.com
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Made the circuit for about $18 from local electronics store (Ace electronics in Houston). Works great.
You've got mail. I would be happy to post this on the DIY-EFI ftp page, but I can't get it to upload. I am a sbuscriber to the lists but when I try to upload, I get a message saying I don't have permission to upload. If someone could help me do this it would be much appreciated.
Car: camaro
Finally getting around to building this I have a question on the schematic though. The way it shows the pots wired does not make sense. Is it supposed to have the wire from chip to the varing portion and then one lead to ground and the third lead of pot unused? With the way it shows now the voltage from the chip going in to the pot would cancel out going through varing portion of pot. Hope this is making sense what I am trying to say.
Thanks Chris
Thanks Chris
Thanks Chris
Thanks Chris
Code:
chip |
_
. Edit: Hmm maybe I'll get you more confused with my bad diagram.
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
Hey HaulnA$$,
Could you send it to me too please vettxtc@comcast.net. I will put it in a folder on my website server..
Thanks Chris
Thanks Chris
Originally posted by -=Jeff=-
Hey HaulnA$$,
Hey HaulnA$$,
Car: camaro
I'm not an electronics guy by any means but if they are rheostats then you would only need two of the three legs on the potentiometer. Now based on diagrams ALEXJH put up the variable resistor picture is wired opposite of what the schematic shows?? Sorry for confusion I just want to solder this once and make sure it is correct.
Chris
Chris
Chris
Chris
Heck, if it doesn't work, just clip one of the leads.
Chris
Chris
Car: camaro
Ok, I have a friend who is helping me and he is the one who brought this up to me. Thanks for the help everyone we'll wire it the way it is shown. I kind of wondered since no one else seemed to say there was anything wrong.
Thanks again
Thanks again
