OBD I cable to serial question.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Has anyone ever tried this companies cable on the TunerPro program??
Scroll about half way down, its only $30.00 for the cable. I know Craig Moats has one too but he only has the USB version and my computer's USB port no longer functions...
Besides its only $30 compared to $80
http://www.easediagnostics.com/perso...cing.htm#per10
What is the link???
John
John
Car: 91 RS
unfortunately, the single trans cable will only work at 160 baud. If you want to look at the 8192 baud datastream, you need to use either the max232 circuit or the 2 transistor one.
Here's the links:
http://www.home.aone.net.au/techedge/vehicle/2tran.gif
http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm
Here's the links:
Car: 1991 Camaro Z28
Originally posted by 2new2funny
What's the difference between 160 baud data and the other you mentioned? I'm running a 65 ECM....
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I imagine the $30 Ease cable is short and will just connect to thier OBDI interface, which has like a 25pin serial connector. after the interface you goto your PC serial port with a 9pin cable.
You could cut the end of the 30$ EASE cable off and put your own end on it I suppose....but the the cable is not that long to begin with..
PS I have the EASE Scan tool personal version for OBDI, that is how know this..
HTH
HTH
I would imagine you could still buy an extension cable with a 9 pin on one end and a 25 pin on the other...
John
John
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
