WB hac
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
WB hac
What am I doing wrong, I put my bin in and add the WB hac and everything looks good but when I install the memcal in the car my data stream quits working. Can anybody help.
BTW.... it worked the first time I tried it now it won't.
I even tried it in a different car and different PROMs.
I even tried Mike Davis' AXXC..WB.bin from his site.
Same results
Same results
Update....I tried an AUJP and it works WTF?
that happens to me too. i don't have the wb hac, but sometimes when i burn a new prom, the datastream doesn't work. I still can't figure out what it is, but it's good to hear that you got u're problem fixed. where can i find the wb hac? with enough funds, i might want to go with that route.
Car: An Ol Buick
Engine: Vsick
If you have the service number of the AUJP you did get to work, posting that, might help others in the future.
I took a copy of the one on Mike Davis' site with the WB in it. I'm not sure which one he uses. I still need to get the AXXC to work as I have a 6 spd.
See this post:
https://www.thirdgen.org/techbb2/sho...50#post2031050
