Dynoing tomorrow...Will Diacom in ALDL hurt power?
Old Oct 15, 2004 | 07:34 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm taking my car to be dyno tested tomorrow. If I datalog the pulls with Diacom will it hurt my total power? I don't know that much about the program...does it cause the car to run in ALDL mode?
Old Oct 16, 2004 | 06:34 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Dynoing tomorrow...Will Diacom in ALDL hurt power?
On the bottom of the screen, is *mode*, click on that, then *normal*, and then link, Diacom will be invisible to the ecm.
Old Oct 16, 2004 | 12:49 PM
Car: 89 IROC-Z
Engine: 383
All mine has is diagnostic and ALDL mode....which do I want? I'm leaving in 10 min. If I don't know I'll run one in diagnostic and a pull with nothing .
Old Oct 17, 2004 | 02:56 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
On MAF cars, there is no "Normal" like SD cars. You need to choose "ALDL" - Diagnostic Mode is intended when you have a problem and need to override certain sensor readings.
ALDL Mode also does slightly alter the engine when connnected, but not enough to seriously affect anything. Besides, you have no choice if you want a "scan" while on the dyno. Especially, if you want to see if any detonation is occuring and how much timing it is pulling out.
Old Oct 18, 2004 | 07:47 AM
Car: 89 IROC-Z
Engine: 383
Yeah I ran 1 pull in ALDL mode......too bad the car ran horrible. Ever since the night after I did my chip tuning it's been running worse and worse. I only put down 265 horse and 334 torque on my pull. I could only make one cause it started leaking coolant somewhere...might just be the lower hose though.
I'm wondering if I'm having problems because I still have the romulater plugged in instead of the actual chip right now??
Otherwise I'm gonna start checking for things like a blown head gasket or something.
Old Oct 18, 2004 | 03:34 PM
Car: Death Mobile
Engine: 666 c.i.
When I was helping a buddy tune his MAF car, we had a Romulator, Diacom and WB all hooked up. We did a "pre-tune" on a long hill to try and get the spark and AF ratio where we felt we wanted it to be before the actual dyno run.
No problems using any of the equipment.
MustangBeater20
Oct 29, 2022 09:20 PM
Reborn756
Sep 4, 2015 03:42 AM
sailtexas186548
Aug 24, 2015 10:11 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
