Memcal Differences - Tuning woes
Old Oct 29, 2004 | 06:34 PM
HyperSpeed's Avatar
Ok after endless hours of messing with the bin with no real results I am beginning to think perhaps I have other issues. Without going into detail, my simple question is whether there were diffences in the memcals produced. I have a couple and they all came from 7730 ECUs but were all out of V6 cars. Are the V6 and V8 memcals different? If so how do I ID a proper one for a V8?
Old Oct 29, 2004 | 08:12 PM
92GTA's Avatar
From what I understand the only difference is the CAL-PAK, the knock sensor circuitry next to the PROM, that is different between V6 and V8 cars. So yeah they are not compatible, you should find a V8 MEM-CAL so when you go into limp more it will work correctly.
Anyone please correct me if I'm wrong...
Old Oct 29, 2004 | 08:28 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The memcal sets the hardware sylinder select so you need us use one that matches the cylinder count of the application.
Post the 4 digit letter code on the AL sticker, and maybe someone can look them up with their magic decoder ring.
Old Nov 1, 2004 | 11:57 AM
HyperSpeed's Avatar
Thanks. Grumpy, I don't know what you are referring to as the AL sticker. I don't have the memcals that I have been using with me at the moment but I do have an extra one sitting here without a ZIF socket that i was thinking about trying. Its got the original chip on it still. The memcal has the following number on the side of it; 68767 8839.
The chip itself has a sticker: DELC APUC 2410
Someone please decode away...
I was also told that the 6 cyl unit may work but will always throw the cyl select flag/code. Whether there are other detrimental effects I'd really like to know.
FireDemonSiC
Sep 3, 2015 12:31 PM
Keith5
Aug 27, 2015 04:37 PM
ezobens
Aug 19, 2015 10:29 PM
Thirim
Aug 13, 2015 03:09 PM
Jake_92RS
Aug 11, 2015 10:39 AM
