speed limiter questions
Old Nov 12, 2004 | 07:07 PM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
i have a 94 trans am 5.7 lt1 . the only mods i have done is put 3.23 gears under it . the car came stock with 2.73 . here's the problem, the car shuts down at 110 mph. but that an inaccurate reading because of the lower gears . so top speed is about 85 mph. if i put a ecm out of a trans am gt (which has no limiter) will that get rid of the 110 limiter? i know about the hypertech but they cost a lot of $$ . any help would be great
Old Nov 12, 2004 | 07:33 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You need to buy the equipment and DIY. It is the only way to also correct for the different gear ratio.
Old Nov 13, 2004 | 11:57 PM
Cliff92Z's Avatar
Car: 1992 Z28
DIY I know you can change the constant to eliminate the limiter but I thought you had to change the drive/driven gears at the tailhousing to recalibrate the speedo? Or buy some sort of electronic recalibrator?
Also, you have a 94 TA and wouldn't really fall under the 'thirdgen' board.
What year TA GT are you planning to get the ecm from that has no limiter?
Old Nov 14, 2004 | 09:31 AM
gta007's Avatar
94 gt ecm
Old Nov 14, 2004 | 11:46 AM
11sORbust's Avatar
www.tunercat.com has the software.
http://www.akmcables.com/ic.htm has the cables.
You'll need to check if you diagnosic connector is OBD 1 OR 2.
94-95 is a transition year and GM use both connectors. So for the total cost of about $150, you can fix the speedo problem. Since you'll have the software you might as well tune the ecm for more power.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
djmarch
Aug 11, 2015 10:22 AM
