VSS Speedo calibration
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
How do I figure VSS Ratio in the ECM Constants table in CATS Tuner? Can this be used to calibrate the speedo for rearend gear changes?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: VSS Speedo calibration
to calibrate for rear end changes, you swap plastic gears in the trans.. just like cable driven speedos.
Car: 1992 Z28
Re: Re: VSS Speedo calibration
Originally posted by MrDude_1
on a 3rdgen, the VSS is a set number of pulses per mile.
http://www.dakotadigital.com/Detail....-5/product.htm
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
92BLKL98, the preferred way is what MrDude_1 said, you can also go with what Cliff92Z said, both will work.
i don't know about CATS, but with TunerPro RT with a 730 ECM running the AUJP bin with either 8d_v03 or Super_8dm2 ECU files, i know there you can make changes to alter the speed reading in the ECM.
the 8d_v03 ECU file is easier to set it with because it uses
0 - 255 for the setting where Super_8dm2 uses pulses per mile & when you change the pulse per mile enough the accept the
change, it changes by 1 number in 8d_v03.
as to how to calculate how much & which way to change it, i have no ideal, that would involve math & for me it was easier to run it on the dyno using real time emulation & my lap top.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
1990, 2001, 350, 700r4, 8dv03, camaro, correction, ecu, georgia, powder, recalibrate, speedometer, springs, tpi, vss
