Changing values in bin
Old Jan 8, 2005 | 11:14 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
Is there a place in the bin where I can change the temp at which my secondary fan comes on? I looked around in Tuner Pro and did not see anything. Am I missing it?
Old Jan 8, 2005 | 11:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Changing values in bin
Not in the '746 ECM. Fan is controlled by the switch in the pass side head between 6 & 8.
Edit: noticed you mentioned secondary fan, this is the '87 TA? IIRC the answer is the same as the '746. It is not under ECM control.
Need to post which ECM/vehicle in order to get the best answer.
RBob.
Old Jan 8, 2005 | 12:04 PM
azvolfan's Avatar
This is on my '92 camaro with the 8746 ecm.
Old Jan 8, 2005 | 01:19 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Thats one of the sucky things about most TBI ecm's. I wonder how hard it would be to make a patch that would incorporate the fan control into the ecm? That would be very cool. Man I need to get into source code.
scottmoyer
Sep 5, 2015 09:33 AM
z28_AJ
Aug 27, 2015 08:59 PM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
