Fanno
Car: 89 Formula 350 WS6
Engine: 383 miniram
Fanno
ok so what the hell is FANNO anyway and how do you set it up? (i assume it is the fan "normally open" switch) i have tunerpro, prominator and a/c delete.
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Fan "normally on"...... Has to do with the A/C compressor high pressure switch. 89 and up you check the box for "NO", 88 and earlier leave it unchecked. someone please correct me if I'm wrong.
If you have the A/C delete, don't mess with it. Just set the fan temperatures where you want them to come on and shut off at.
Engine: 383 miniram
yes, i believe you're right. what you said works. if you mess with the fanno flag, the fans come on inappropriately. thanks. :-)
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Sweet, I was wondering why my fan would run all the time when I uploaded the AUJM.bin. The FANNO flag is checked. Hopefully that will solve that problem.
