AE - add fuel vs. timing?
Old Feb 4, 2005 | 11:30 PM
nhromyak's Avatar
Car: '73 Chevy Blazer
Engine: BBC - 408
Transmission: SM465
How do you tell you should add fuel, take out fuel, OR
add timing, or take out timing in AE?
7730 $8D -
No wideband, no knock sensor - is it possible?
What does the engine "feel" like?
Thanks!
Old Feb 5, 2005 | 01:01 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
No knock sensor is going to be a big hindrance to your trial and error tuning. The knock sensor makes it really obvious datalogging when you' have pulled in too much timing. Why don't you have one? I have a TPI on a 1969 327, and the knock sensor directly replaced the already existing coolant drain plug on the lower pass. side of the engine block. I used a 350 knock sensor and knock module (the later ECU's won't need the external knock module). If you are running enough timing to maximize your performance, you will be on the cutting edge of having too much timing under some load/rpm combinations. When you have a knock sensor, this is a good thing.
Old Feb 5, 2005 | 01:05 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i would say a knock sensor is one of the main guides to go by when tuning.
Old Feb 5, 2005 | 09:22 AM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
I guess it's time to get coolant on me....
I purchased a knock sensor, but I need to add the wiring, and install it. I haven't been able to locate a suitable place on the block for it yet though.
Thanks for the replies.
Old Feb 5, 2005 | 09:24 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: AE - add fuel vs. timing?
7730 $8D -
Thanks!
Too rich/ lean, can easily be mistaken for too much/ not enough timing. It can be done, but would take a longgggggg time.
Old Feb 5, 2005 | 09:25 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Gotta remember thou, they can be totally blind to preignition.
Old Feb 5, 2005 | 10:49 AM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
Re: Re: AE - add fuel vs. timing?
heh, yah, it's been a year, and I am sick of it.
Maybe I should look at a 7749
Old Feb 5, 2005 | 02:41 PM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
And that's reason for making 2 (or 3) degrees less (negative) when you get a "little bit of knock" in an area - correct?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
justin57
Aug 20, 2015 07:05 PM
