4K bin in a '165 memcal
Old Feb 16, 2005 | 12:43 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I am working on a friends prom in his '86 Camaro LB9. It of course has the '165 computer with $32 code. I remove the prom and erase it, just barely noticing the AMU broadcast code on the foil sticker. I think nothing of it. I write the new bin with $6E code and attempt to program it to the prom. It does not even start, instant failure.
I check to make sure GM didn't put a 32K eprom in and they didn't. Sometimes they do even in MAF cars.
I then research the AMU BCC and find out it's 4K bin, not a 16K bin as expected in a '86-89. In fact the whole AMU series is 4K. The netres chips are even different in this AMU memcal.
I know the '85 used a 4K bin. Anyone run into this before?
Old Feb 16, 2005 | 05:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
John, doesn't sound right to me. The ECMs using 4KB chips typically have another 8KB in on-board ROM. The '165 doesn't have ROM for this purpose (at least AFAIK).
Check to see if the chip is a 256kb (32kB). If so then either need to double stack the bin or offset the burner buffer to the upper half of the chip.
RBob.
Old Feb 16, 2005 | 07:33 PM
Engine: 4.0L
RBob.
It didn't sound right to me either. That's why I posted here. GM does strange things. The AMU BCC says 1986 LB9 but the manufacture date is late '85 so it COULD be a 4K eprom I think if they carried it over from the '85 ecu (I know the '85 was a direct eprom, no memcal).
I really don't think the eprom is a 32kB chip, the ones that were on a MAF car stated so on the top (27C256). I haven't determined the manufacture or size of this particular eprom by the few numbers on top.
Lastly, I need to look at the AMU BCC's and see what Tunercat $32 reads them as since they're only 4K in size, it might not even open. If it does open I am curious as to what's different...........
Old Feb 17, 2005 | 01:50 AM
Engine: 4.0L
I wish I would have saved AMU.bin now. I don't have absolute proof that it is in fact a 4K bin or not. I am guessing it is because the others in the AMU series are 4K bins but most are LO3 engines, not LB9's......
I have the following info directly off the eprom on the memcal. Can someone tell me what size it is(type)?
16040581
796 K
8602 5010
Old Feb 17, 2005 | 06:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Count the pins on the EPROM. A 4 KB (32 Kb) EPROM has 24 pins, the 16 KB (edit: 128 Kb, not 64 Kb as originally posted) and 32 KB (256 Kb) EPROMS have 28 pins.
RBob.
Old Feb 17, 2005 | 10:55 AM
Engine: 4.0L
Count the pins on the EPROM. A 4 KB (32 Kb) EPROM has 24 pins, the 16 KB (64 Kb) and 32 KB (256 Kb) EPROMS have 28 pins.
RBob.
That's not a true statement. Memcal cars have 28 pin eproms.
A 27C128 (16K) eprom has 28 pins
1 27C256 (32K) eprom also has 28 pins
Old Feb 17, 2005 | 11:27 AM
JPrevost's Avatar
Car: 91 Red Sled
He just said that, re-read it and you just repeated what he said.
As for the memcal's, they all are 28-pin meaning they're all at least 16k or larger. The 24-pin chips GM used are 4k and that 4k was full of calibration look-ups, not actual code, maybe a little be very little. The on-board rom has the code and it's 8k full of stuff. I HIGHLY doubt that GM got all of the $32 code on a 4k chip AND had room for the speed density tables. They just wouldn't do that.
Use a hex editor to open the saved bin and do a checksum. Also the mask ID should be at the top.
Old Feb 17, 2005 | 12:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Then the EPROM in question is one of these, not the 4K. Note that I edited my previous post from 64 Kb to 128 Kb. This is what matches the 16 KB EPROM size (bytes & bits, glad I kept nybbles out of it ).
(For anyone wondering about the different Kb/KB's: upper case B is bytes, lower case b is bits).
RBob.
Old Feb 17, 2005 | 03:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: 4K bin in a '165 memcal
AMU is from a 1225330 ecm.
A, AUM is from a 1227615.
HTH
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
sreZ28
Oct 22, 2015 08:21 AM
lethaldomestics
Sep 21, 2015 01:18 PM
