Can't find an ABYA .bin....gotta few questions
Old Feb 20, 2005 | 03:55 PM
Mike86Z28's Avatar
Car: 98 Z28
I preparing to start tuning my car when my PROMinator gets here. I have been looking around for a ABYA .bin so I could reference the timing table info because I was going to use that for an ARAP bin. Is there a similar bin that uses the "stock" timing tables, since I hear the ARAP timing tables are pretty aggressive?
I'm having problems with what I believe is false knock and don't want to run anymore timing until I get the knock issue taken care of. I think it is the exhaust hitting the oil pan, but it is retarding the crap out of my timing and my old knock sensor is being a pain to remove.
Thanks in advance for any help guys.
Old Feb 20, 2005 | 06:43 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Can't find an ABYA .bin....gotta few questions
IMO, get the mechanicals right first. Having a K/S will save you countless hours in yanking plugs looking for detonation.
Old Feb 21, 2005 | 12:16 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
My car uses the abya bin also. Its availible at the diyefi boards.
Old Feb 22, 2005 | 12:28 PM
Mike86Z28's Avatar
Car: 98 Z28
Re: Re: Can't find an ABYA .bin....gotta few questions
I was going to replace it with a new K/S and see if that helped any. I also think my old K/S is in the block to tight making it more sensitive because I couldn't budge it with a ratchet/socket combo. I'll have to drop the starter and possibly the exhaust to get enough room and leverage with the channel locks to pry that sucker loose. I'm sick now though so I don't have to worry about doing anything to the car for awhile.
Old Feb 28, 2005 | 09:35 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I have the ABYA bin if you still need it. Send me a PM or email
I was (still am) trying to figure out false knock. I think my scan tool was the source of the problem!
PS you have the same exact ride I have!
Old Mar 1, 2005 | 07:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Very well may be. A 10K across A & B on the ALDL will cause the ECM to add timing. Unless that cal term is zero'd out.
RBob.
Old Mar 1, 2005 | 09:05 PM
Car: 1988 IROC-Z
RBob.
Yea I think you got it right. I been using scan tool from Ease Diagnosics, for a long time, until late last summer/fall. I learned the hard way they use ALDL mode ONLY to connect to the ecm and get data. So I tried TunerPro last year and saw very little spark knock under heavy loads. With my homemade interface, i put in a switch to take out the 10k after connect, and I still get data. Sometimes would even connect up without the 10k!!
So going forward I will be using TunerPro more often!
Caspar
Jun 19, 2016 11:19 PM
pfsteichen
Feb 9, 2016 06:59 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
