AS11 LST file ?
Old Feb 28, 2005 | 03:34 AM
Z69's Avatar
Z69
AS11 LST file ?
I have the l and c OPT in the asm file and it appears as if they are working the dos window.
Tried to do them at the command line also.
So how do you get it to make/save an lst file?
I had to go though the bin in an editor to figure out if what I did actually fit. pitb...
Old Feb 28, 2005 | 06:36 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
- xlos were the switched used to get all the files.
IIRC.
Old Feb 28, 2005 | 06:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: AS11 LST file ?
With the OPT L option the list file should be output to the screen. If so, then redirect it to a file:
as11 mycode.asm > mycode.lst
RBob.
Old Feb 28, 2005 | 12:03 PM
Z69's Avatar
Z69
Thanks RBob
I didn't know how to do a redirect.
John, it AS11 not 68AS11.
Old Feb 28, 2005 | 05:49 PM
JP86SS's Avatar
Old Feb 28, 2005 | 10:02 PM
funstick's Avatar
ive got to get better at writing vb. this crap with asmbeling stuff in dos is just crazy.
Old Mar 1, 2005 | 12:51 AM
Z69's Avatar
Z69
I had to make a batch file to get me to the right directory since I put it so far down in the tree w/ long file names.
Never can remember where to put the ~ at.
Made it echo the command line syntax while I was at it.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
80smetalfan
Sep 22, 2015 02:55 PM
