Timing issues - need help with studder
Old Mar 4, 2005 | 10:58 PM
tail's Avatar
Car: 1991 Formula
Engine: 355 with ported & polished vortech heads and a 269 cam.
Transmission: 700R4 (w/ shift kit) and 2000 stall TC
Ok, I installed the cam retainer that wasn't installed to begin with, and now the car performs much better. However I have a studder at around 1600rpm that is almost like i'm bouncing the gas peddle (which i am not). I have a log here, if anyone would be willing to look at it. My WOT tuning is way off too i'm sure.
http://www.dlu.cc/Tpics_files/GM030401.csv
Current BIN (with this log):
http://www.dlu.cc/TPics_files/Marilyn.v4f.bin
Please help?!
Old Mar 5, 2005 | 01:24 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
From the datalog, it looks like your picking up alot of P/T detonation, according to the K/S, anyway. Every time you give it even modest throttle, the ecm pulls timing because its seeing knock. Given that you just got the setup together, Id operate under the assumption that it really is detonation and try to get the fueling correct and work with the timing.
Keep in mind that each 'count' there is really counts x 256. That means that with only one or two additional counts in a data log youll still loose a couple of degrees of timing there.
If the surging happens when the car is warmed up it could be the PID stuff for the O2 not being quite right. Mine has a surge in closed loop as well, albiet not quite as bad. Have closed loop disabled due to my D/S header having a large crack in it and the engine runs nice and steady in open loop.
Bascially it needs to be tuned.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
