Inj. PW voltage-3.0v
Old 03-05-2005, 11:23 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Im still having a problem with Tunerpro show my PW to not be going over 0.50msec. With a volt meter the voltage was going over 3.0v+ when giving it wot and going back up numeriacally in order. Is this correct?
Old 03-05-2005, 10:56 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Where are you measuring from? The tps?
If its at the connectors for the injectors then it wont tell you a whole lot, although I guess you could use it as a primitive dutycycle meter.
Old 03-06-2005, 09:48 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
im measuring voltage across the injector leads at the connector.
Old 03-06-2005, 01:02 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Re: Inj. PW voltage-3.0v
Voltage and pulse width are totally different things. Pulse width is TIME that the injector is on, and the injector is supplied with battery voltage. The reason you don't see batt voltage across an injector is because the voltage is peing pulsed on and off, and your meter is picking up an average voltage, even though it's just going from battery volts to 0 volts.
88 350 tpi formula
12-28-2002 11:31 PM
junkcltr
02-14-2002 02:02 PM
junkcltr
02-14-2002 11:33 AM
Free Bird
06-19-2001 09:26 PM
Quick Reply: Inj. PW voltage-3.0v
