A/D read SR
Old Mar 6, 2005 | 03:47 PM
Z69's Avatar
Z69
A/D read SR
Code:
* ADREAD.SRC
* Read serial A/D
* Call with:
* Ch num in A reg
* Return with:
* A/D result in A reg
* or ) if A/D or serial fails
* TYPE $8D, ECM P/N 1227730
LF0D2: PSHX
LDX #$4000 ; GM Regester
SEI ; HOLD INTERUPTS
BCLR 2,X,#$08 ; SELECT SERIAL A/D CHIP
STAA 0,X ; CH TO DON IN SSR
BCLR 1,X,#$80 ; CLR b7, SEND CH NUM
; 8 SCLK's delay
PSHB
MUL
MUL
MUL
PULB
LDAA 0,X ; LD TEST CH RESULT FM SSR
STAA $01AE ; SAVE RESULT
; delay 64 cycles
PSHB
MUL
MUL
MUL
MUL
MUL
NOP
PULB
; READ A/D TEST CH
LDAA #$B0 ; SET A/D CH 11 FOR TEST
STAA 0,X ; WR TO SSR
; delay
PSHB
MUL
MUL
MUL
PULB
LDAA 0,X ; GET RESULT
BSET 2,X,#$08 ; DISABLE SAD
CLI ; INT'S BACK ON
PULX
RTS
It looks like the result is stored at $4000 and $01AE after the first 8 delays.
Then another 64 cycles and ch 11 is read and stored at $4000 again. Which wipes out the first result.
Or is this a 2 step process and the first result is an intermediate result?
Just how does this routine work?
Old Mar 6, 2005 | 06:46 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This routine is easily confusing. The best way to look at it is that on entry Reg A contains the channel to be converted. On exit, Reg A contains that channels data.
The reason it is confusing is the order of data conversions.
The new desired channel is set and the conversion started. After a delay the last conversion data is retrieved. This data is the test channel, and is previous to the current acquisition data channel.
Once the test channel data is retrieved another delay occurs. At the end of that delay the desired channel data is retrieved. And the test channel conversion is started.
Now, the routine doesn't wait for the test channel, it returns with the desired channel data. The test channel data value is retrieved the next time this routine is called.
RBob.
Old Mar 6, 2005 | 08:13 PM
Z69's Avatar
Z69
Thanks Rbob
Is that because the adc chip needs something to push the old data out so to speak or trigger a send...?
Old Mar 6, 2005 | 08:42 PM
AlexJH's Avatar
Engine: 5.7L V8
Originally posted by Z69
Thanks Rbob
I can't speak for the specific ADC chip in the ECM, but there's usually some delay in ADCs for reading the analog voltage, just due to how ADCs work (charging up a capacitor).
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
