Prom
Old Mar 14, 2005 | 09:07 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Prom
What the heck is a Prom? Is it the computer?
{edit: changed one word, mod}
Old Mar 15, 2005 | 10:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
PROM is the acronym for Programmable Read Only Memory, or, the chip that holds the calibration data. Yes, in the computer, sometimes called the ECM.
By changing the values within the PROM a user is able to change the tune of the engine. Items such as spark advance, AFR, TCC lockup points can all be updated (among others).
RBob.
Old Mar 15, 2005 | 09:59 PM
Engine: 400
So my carburated car doesn't have this. I've got a distributor right? Thanks for the info!
Old Mar 16, 2005 | 06:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If your car is a stock US based model then yes it has an ECM. The carb will be a computer controlled carburetor (CCC) and the distributor will also be under ECM control. Same with the TCC, EGR, and AIR. If it is still factory stock.
At key on, engine off, is there a clicking coming from the carb? If so then a sure sign it is a CCC model.
RBob.
Old Mar 16, 2005 | 07:06 PM
Engine: 400
Hmm. Well, my car has a different carb and distributor on it. I don't ever recall her clicking when the key is in the "on" position, but maybe it does. I'll check it out next time! Thanks
Old Mar 16, 2005 | 07:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, very possible. Many 3rd gens have had items swapped out on them. Which is why I stated 'stock US based model.' If it doesn't have the factory stuff, and US emissions isn't in the cards, then just keep it in good tune and enjoy it.
RBob.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
