Injector Constant
Old Mar 18, 2005 | 08:38 PM
smithtc's Avatar
Injector Constant
22.36 lbs/hr @ 40psig is what the stock computer chip has for my car (89 350 TPI). I have 24 lb/hr SVO injectors in. I hear they are rated at 43psi. I have read where I need to change my injector constant to reflect the injector change....
Do I just set it to 24 and call it good, and let the computer do the rest for me? or what?
TC
Old Mar 18, 2005 | 10:43 PM
EdgesZ28's Avatar
Car: 91 GTA - 94 TPI Suburban
Everything I have read rate them at 39 psi, without vacuum.
If you set them at 43 psi, you need to use an injector constant of 25.2.
Ed
Old Mar 19, 2005 | 01:07 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Nope, use the stock 43 psi setting and an injector constant from 24-24.5 should get u pretty close to the ballpark :-)
Ran 2 sets of these on my vehicles and some more on friends cars.
Do some searching and you will find that this myth was debunked :-).
later
Jeremy
Old Mar 19, 2005 | 02:11 PM
EdgesZ28's Avatar
I did a little searching and found on page 102 of the Ford Performance Products catalog that their "injectors are flowed at 40 psi differential pressure". http://www.fordracingparts.com/downl...gs/2005-pp.pdf
Accel's catalog (page 231) states a stock Ford setting is a "static" pressure of 39.6#, and most GM are set at a 44.1# static pressure. http://go.mrgasket.com/pdf/ACCELfuelinjection.pdf
Are "static" and "differential" one in the same when defining an injector's flow rate? At least for purposes of setting an injector constant. Ed
Old Mar 19, 2005 | 04:46 PM
smithtc's Avatar
I believe what 3.8 was referring to was recent flow tests done by Rich at Cruzin Performance. Of the many SVO injectors that come through his shop for cleaning/rebuilding....they spec out at 24lb/hr at 43psi...
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
