question about control of IAC
Old Mar 31, 2005 | 12:41 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i have a new custom built throttle body on my car and i can't get my idle to come down. i'm pretty sure that my problem isn't with the butterfly or anything, i think that the idle air control valve isn't closing enough. my question is, does the ecu have preset 'steps' for the IAC or should it adjust and try to bring the rpms to the set 'desired idle speed' regardless of any other conditions? i'm thinking about shaving down the mounting flange where the IAC bolts in just to move the pentle in further but before i take my chances with that, i want to see what you guys say about its operation coming from the computer. thanks.
Old Mar 31, 2005 | 02:08 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: question about control of IAC
Jump A->B on the ALDL. Key on for at least 30 secs., then with the key still on disconnect the IAC. Start engine, the IAC will be fully closed, and that idle is what your min idle speed is.
The code had what's called, anti-stall, if the ecm thinks the engine is going to stall, it will keep it at a high idle.
Old Mar 31, 2005 | 02:27 PM
Car: 91 Camaro
thanks, i'll give that a try!
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
