Shorted out fuel pump sig wire, now its dead.
Old Apr 7, 2005 | 11:03 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I shorted out the +12v fuel pump sig wire that does to my fuel pump relay, now there is no more +12v there. Vehicle does run, as +12v does go to the FP relay through the oil pressure switch. So now for me to get fuel pressure, I need to crank the engine for a couple seconds.
My question is: Is my ECM (747 btw) NFG, or can some sort of part be replaced on the curcuit board, or something. Other than non +12v on this wire (I think its pin A1), the ecm works perfectly.
Old Apr 8, 2005 | 05:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The output transistor popped, possibly the trace fried, but every one I've seen has been the transistor. Quite common at that. Use a 2N2907 (metal can) transistor to replace it. Looking at the top of the PCB, harness connectors at your stomach, lower right corner. Two transistors right next to each other. It will be the larger of the two.
RBob.
Old Apr 8, 2005 | 06:51 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I got a 747 out of the junk yard that had the trace and the transistor burnt. Fixed both and walla everything is right in the world.
Old Apr 8, 2005 | 09:24 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Thanks alot guys.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
