throttle follower $6e
Old Apr 10, 2005 | 11:45 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
how do i lower the throttle follower iac steps on a $6e? what address is that at since tunerpro has no provision for that field?
Old Apr 11, 2005 | 09:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Looks like the max steps are at $55A, and the gain term is at $559. The gain term controls how many TF steps are used relative to the TPS%.
RBob.
Old Apr 11, 2005 | 12:05 PM
cormyr's Avatar
Engine: 383 miniram
RBob.
you the man RBob. lemme try it and see if it works.
btw for future reference, where can i get that info for myself?
Old Apr 11, 2005 | 12:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Look for the $6E hac over on Moates site.
RBob.
Old Apr 11, 2005 | 01:47 PM
cormyr's Avatar
Engine: 383 miniram
ok, i tried it and sure enough it worked. thanks so much. i set the max TF steps to 18 and it really tamed things down alot. doesnt race all over town anymore when my foot is off the gas. for some reason though it still reaches some high iac steps, not often, but once in a while and then it doesnt return until i come to a complete stop for a few seconds. any suggestions?
Old Apr 12, 2005 | 01:47 PM
cormyr's Avatar
Engine: 383 miniram
ok i think ive figured out when its happening at least. before the engine reaches full operating temp the iac will follow the throttle for the most part but then when i take my foot off the gas it stops following and stays somewhere in the vicinity of 40-55 iac steps and wont move again until i come to a complete stop for several seconds, then the steps decay down slowly. if i hit the gas again the iac continues to follow throttle but the same thing will happen until the car is fully warmed up and i have driven around town a bit. then its fine. does it have to do with learning? added steps for coolant temp? or is there some other factor adding steps that i don't know about? i would have guessed sticky iac but my last one did the exact same thing.
92firebirdguy
Sep 1, 2016 07:53 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
Randomtask2
Sep 7, 2015 05:06 PM
