still a slight idle surge in open loop
Car: 89 Formula 350 WS6
Engine: 383 miniram
i have this thing pretty close to running well but there is still a slight surge at idle in open loop. it seems to be completely independent of the iac and spark advance. i disabled stall saver, which helped, and flattened out the idle ranges of the SA table. the iac is not causing it because it is only varying 1 or 2 steps here and there while this is happening and the SA is staying pretty much stable too, yet the rpms incease and decrease in a classic surge pattern. the only thing i can see thats off is that when this is happening i am running a bit rich, but i thought the afr needed to be rich on cold startup. surging stops when engine temp warms up a bit and afr approaches stoich. any suggestion?
Car: An Ol Buick
Engine: Vsick
Re: still a slight idle surge in open loop
Generally adding timing, and running a lil rich helps. I'd be careful thou not to get too carried away with adding timing thou.
