vats delete
Old Apr 10, 2005 | 08:33 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
vats delete
Hi,
VATs Is vehicle anti theft right. Why do people remove that from there chip? JUst wondering is all please.
Old Apr 10, 2005 | 11:54 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I don't have the VATS module or the ignition switch with the resistor contacts. The resistor turns on an output in the module to output a 33-66 hz square wave (IIRC) to the ecm signaling it's ok to fire the injectors.
I did it out of necessity of a retro fit, IMO most do it because it's a PITA and something else thats bound to break one day.
Old Apr 11, 2005 | 12:14 AM
Z69's Avatar
Z69
you should've
Vats Delete search result
Old Apr 11, 2005 | 11:04 AM
8UpAFord's Avatar
Car: 1988 Corvette
So yes it is a part of security then. Yeah so disableing this sillyness should be oK? Oh one thought if i disable this will i be able to use a plain eginsion key? I think the module gets it's input from those special $250 doller keys right??
RS Reaper
Oct 17, 2018 07:52 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
