Turn off EGR in 6E
Old Apr 12, 2005 | 10:46 AM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Turn off EGR in 6E
Guys, How do I effectively turn off the EGR function. I want to check to see if my car idles better without it active. How does it physically shut off? Does the computer shut off the vacuum Selenoid?
Old Apr 12, 2005 | 11:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Turn off EGR in 6E
Set the EGR enable temperature as high as possible. Or, in the case of MAF ECMs, relocate the MAT to the intake air stream.
RBob.
Old Apr 12, 2005 | 11:29 AM
Car: 1987 Iroc-z
I got a box that says "Disable EGR if MAT < X". It's set to ".50".
Is that what you are talking about?
Old Apr 12, 2005 | 11:35 AM
Car: 1987 Iroc-z
What is the MAT?
Old Apr 12, 2005 | 12:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, set it to disable EGR if MAT is less then 150 C. MAT: Manifold Air Temperature.
RBob.
Old Apr 12, 2005 | 12:07 PM
Car: 1987 Iroc-z
Does the computer shut this off by stopping the EGR selenoid?
Will the car run differently?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
dyeager535
Aug 28, 2015 08:10 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
