very rich during PE
Old Apr 27, 2005 | 03:58 PM
bennycnu11's Avatar
very rich during PE
I just installed trickflow heads, and a zz4 cam and I have been trying to tune this setup. I am using a 32b mask and moates ostrich. When I enter PE my WB is reading between 8-9 afr. In the Power Enrichment vs RPM table I have decreased the values in there by as much as 15 percent points yet my WB will still reads between 8-9 afr. If my ecm is retarding spark would that cause a rich PE?
Old Apr 27, 2005 | 05:34 PM
Mark 89Formula's Avatar
I had the same problem running the 6E mask with a gutted MAF (screens and fins removed). I changed the MAF scalars at the lower flowrates to get close to a BL of 128 then extrapolated the new calibration curve to the higher flowrates. This amounted to about a 15% change in the scalars and thus the calculated airflow and load for a given vehicle state. I'm not familiar with the 32b mask but if you're running a gutted MAF, this would be something to consider. And yes, I see richer readings when removing timing at WOT without changing any other parameters.
Old Apr 27, 2005 | 08:01 PM
bennycnu11's Avatar
Thanks for the reply Mark, during part throttle all my blms are between 120-130, and my MAF screens are not cut out. I just took the car out again and started logging with winaldl during PE it is not registering any knock(maybe because of all the fuel). I have done some searching and found a thread to calculate how much to change the values in the Power Enrichment vs RPM table and the equation produces a number equal to -50 and up. This just seems like to big of a reduction in fuel. Is there anyone else that can help me?
Old Apr 28, 2005 | 12:24 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
That's insanely rich. The factory cals usually put it in the 11's. WB's shouldn't even register 8-9's. What kind of wideband are you using? If you don't max out the MAF, then only about 17-20% of TOTAL PE (warm engine) is needed (make sure it's calculated correctly, not all .ecu's have it right). But, if you do max it out (255 g/s), extra PE is used to cover up the missing airflow reading in order to keep the same A/F.
Old Apr 29, 2005 | 08:32 PM
bennycnu11's Avatar
the WB is an LM-1 and 8 is as rich as it goes.
Old Apr 29, 2005 | 08:38 PM
bennycnu11's Avatar
how do i see if the ecu is calibrated correctly? before the heads and cam where put in the ecu was calculating the AFR correctly.
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
James Sutton
Sep 23, 2015 02:18 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
