ECU Conversions
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
ECU Conversions
I'm refining the $8D XDF file and am having difficulty getting a handle on some of the conversions.
I borrowed the top list from "Programming 101" and don't have a problem using them. The bottom few are not clear to me.
Can someone assist in getting the list completed correctly?
TIA,
MAT Values come out negative on some entries, might be because of the inverse usage in some points.
TIA,
Code:
; Temperature, Coolant N x (191/255)-40 degrees C ; Speed N x 1 0-255 MPH ; RPM N x 25 RPM ; RPM, low range N x 12.5 RPM ; WOT AFR N x (100/256) AFR ; PE (power enrich) N x 10 ; VE (volumetric efficiency) N x (256/100) 0-100% ; Knock retard N x (45/256) 0-45 degrees ; Knock attack Rate N x 0.0225 milliseconds ; Knock recovery Rate N x (500/256) milliseconds ; Spark Advance N x (90/256) 0-90 degrees ; Spark Retard N x (45/90) 0-45 degrees These I need clarification on, ; MAP N = 256 - (Kpa *(256/80)) Values over 80 Kpa are "-" ??? ; MAT Deg C N x 0.750000 + -40.000000 ; Same as Coolant ?? N x (191/255)-40 degrees C ; O2 Volts (milli Volts) N x 4.440 + 0000 (or should this be 1/256 ??)
Car: check
Engine: check
Transmission: check
For the O2 value: mV = N * 4.42, N being the value in the bin. If N is 106: N * 4.42 = 469 mV
For MAT it depends. The most common used MAT term is a linearized term. This will be the same as CTS: °C = N * .75 - 40. Note that the EGR enable and a handful of diag stuff use the inverse ADC MAT, which requires a table lookup.
For MAP it depends whether the SD MAP term is used, or the ADC MAP. I think most of the code uses the SD MAP term. The conversion for that is: KPa = (SdMap * 0.3125) + 20
RBob.
RBob.
Thanks a bunch
KO1
16
Oct 15, 2015 05:00 PM
