MAF Newbie::Difference in $32B and $6E
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I read in a recent post that the $6E based it's fueling entirely on airflow. I guess I don't understand this, how does the $32B justify it's fueling process compared to the $6E?
Car: check
Engine: check
Transmission: check
The $32/$32B mask can calculate the PW directly from the airflow, same as the $6E mask. Or it can use a 3D lookup table of PW's based on RPM & LV8. Which method to use is selected by an option bit in the calibration area of the mask.
With the release of $6E the ability to use a PW lookup table is no longer present. The PW is always calculated directly from the airflow and engine RPM.
RBob.
RBob.
BumpaD82
Feb 26, 2016 02:57 PM
