Knock and BLMs
Old May 29, 2005 | 11:39 PM
devilfish's Avatar
Knock and BLMs
When I run BLMs at 121 at highway speeds ( 1600-1800 rpm @ 50-60 kpa ), I can use as much as 42 degrees of spark advance. But when I tune the car to run at 128 BLM I got spark retard at the same area. That dont make sence to me. As I am in closed loop the ECM should compensate the rich 122 BLM so that the AF is 14.7:1 ?
Old May 29, 2005 | 11:59 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Compare the BPW.
/N
Old May 30, 2005 | 03:17 AM
devilfish's Avatar
ok will do..
Old May 30, 2005 | 11:07 AM
devilfish's Avatar
The BPW is the same. I dont know what my nock count is. I can log the car on 2 diffrent occasion, with the same IAT, same engine temp, same road. And one time I get spark retard, the other I dont..
Old May 31, 2005 | 12:10 PM
11sORbust's Avatar
develfish, you should know by now that a KS is useless for performance applications.
Old May 31, 2005 | 11:55 PM
devilfish's Avatar
hehe could be true..
If only the knock where somewhat consistent, then I should be sure it whas false knock. Now it comes and goes, wicked....
Old Jun 1, 2005 | 12:25 AM
11sORbust's Avatar
what are the wideband readings?
Old Jun 1, 2005 | 12:57 AM
devilfish's Avatar
During the spark retard the blms is around 126, and the WB reads between 14:70 and 15:25.
Old Jun 2, 2005 | 05:15 AM
devilfish's Avatar
i think I got it sorted. what I did whas to give the engine more fuel at low kpa scale, 20-30kpa, even thou I dont se that low map at 1700rpm it helped with the spark retard. so I whas wrong the KS whas right.
RedLeader289
May 28, 2019 01:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
