Too much electrical resistance
Old Jun 4, 2005 | 02:04 PM
ULTM8Z's Avatar
I was curious about the grounding on the O2 sensor with my stainless headers. I'm running an AFS-74 Delco sensor.
Anyway, I checked the resistance from the sensor body to the (-) battery terminal. Measured about 3 ohms. Is this out of spec? If so, what problems could it cause?
I'm going to have to write a song about this...
"I've been workin' on the misfire, all the liv long day..."
Old Jun 4, 2005 | 05:29 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
3 ohms is nothing,.. depending on the quality of the meter, just the leads will read some resistance, my newest fluke reads the leads anywhere from 0.2 ~ 0.5 of an ohm depending on what the temp is.
*edit*
you got me curious, so i went out & checked mine, read around 4.5 ohms with the stock manifolds.
Old Jun 5, 2005 | 03:30 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Too much electrical resistance
What's more often more important then absolute resistance, is voltage drop. Try reading across the *ground*, with the engine running, and see if you get *any* voltage reading across the ground.
A poor ground can lead to a multitude of problems. It's like asking if you have a sprained ankle, what kind of problems can you have?, it all just depends.
Old Jun 7, 2005 | 11:47 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
O2 sensors are fairly high impedence/low current, so I doubt it's easy to get voltage drop across 3-4 ohms. Could be happening a little, very little, but doubt it's causing any issues.
Edit: wait, you're talking ground side. uh... still should be no problem.
RedLeader289
May 28, 2019 01:47 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lanceflame44
Sep 25, 2015 12:28 PM
