730 + $58 vs 749
Old Jun 17, 2005 | 08:27 PM
fateo6's Avatar
Car: 74 buick apollo
Engine: twin turbo 383
Transmission: TCI comp th400
730 + $58 vs 749
hi what is the diffrence between runnin a 730 ecm with a $58 code vs runnig a 749 ecm?
Old Jun 18, 2005 | 12:36 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am no pro but, it seems that the #1 clear differance is the 749 has a PH driver
Old Jun 18, 2005 | 01:32 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
749 in stock form will only do P+H if wired as a turbo sunbird -- IOW only running one injector per driver, for a total of two. If running PFI, like in the sy/ty apps, it needs high-z injectors, although there is a DIY mod to upgrade the drivers for low-z, that can be found here with a search.
Besides that, the only practical difference that I'm aware of between the two ECMs that I know of is that the 749 has an additional output that could be used for something like a wastegate solenoid. If you use an external WG controller, and don't need P+H, there's no advantage to the 749 over the 730 that I know of.
Old Jun 19, 2005 | 11:51 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
749 can use up to 6 p/h without any mods, wired like the sunbird, if you going for 8 p/H you need to upgrade the drivers...
This is the only reason I'm switching to a -749, going to run 8 p/H.....
Old Jun 19, 2005 | 01:24 PM
fateo6's Avatar
so what do i have to do to run 8 p/h injectors?
Old Jun 19, 2005 | 02:40 PM
Dave_Jones's Avatar
http://mywebpages.comcast.net/p-928/749mods.html
junkcltr
26
Jan 22, 2022 10:53 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
355tpipickup
Aug 19, 2015 10:02 PM
HighHopes85
Dec 3, 2001 06:28 PM
