Initial Spark adv (distr. setting)
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
I have 6 deg in the chip (8D 90 vette).
I checked in the dist and I can't lower the initial deg (without the EST) to 6 deg.
I ended to 8 deg BTDC with the distributor.
(I'm not able to turn far the dist because i have a stock Hei and a Superram plenum. no clearance.. I'm with one of the spark wire against the edge of the plenum...).
Is there some thing wrong if i set the constant "Initial Spark adv (distr. setting)" to 8deg BTDC?
I know that in this way I can look without errors at the SA tables , but I'm here asking if putting it to 8 (instead of 6) I can have some other problem... I'm referring to some hardcoded bias value that is fixed to 6 deg ....
-Beppe-
-Beppe-
Car: check
Engine: check
Transmission: check
Setting the bin value to 8 degs to match the distributor base is correct. It will work properly, there isn't any thing else in the bin that needs to be changed.
RBob.
RBob.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
