Prom DIY Burning
Old Jul 14, 2005 | 07:36 PM
Showcase1186's Avatar
Car: 2000 SS 1991 Z28 VERTS
Engine: LS1 TPI
Transmission: T56 TKO500
Axle/Gears: 4.10 3.73
Prom DIY Burning
I am new to prom burning and my car is running lean. It also will not go in to closed loop even with a stock program. My car is an 86 Iroc TPI With a 355 10.72/1 compression with a Mild cam. I have success burning chips and getting the car running better, but it will not go in closed loop or run rich. Please help!
Old Jul 14, 2005 | 11:14 PM
11sORbust's Avatar
hook up a wideband. The factory o2 can be very misleading. If you have used one then post your a/f ratio charts. Make sure to post the lean area (gr/sec+rpm) AND what you are doing to change the fueling..
Old Jul 15, 2005 | 12:02 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I'm not sure hooking up a wide band is the answer here. Let's start simple.
Take a data log and look at what your O2 is doing while you're actually driving the car. If, when the engine is at normal operating temp (~200 degrees in most cases), the O2 sensor isn't going "up and down" (regularly crossing the 500mv thresh), that's most likely why your car is not going into closed loop.
Old Jul 19, 2005 | 04:51 AM
Engine: LS1 TPI
thanx guys. I \that was helpful, and I figured it out!!!
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
85 Jimmy
Sep 30, 2015 07:56 AM
dusterbd
Sep 29, 2015 08:40 AM
