7747 and tunerproRT temperature reading
Old Jul 18, 2005 | 01:19 PM
SB406's Avatar
Car: 71
Engine: 406
Axle/Gears: 3.42 8.5" 10b
Has anybody else running a 1227747 had an issue datalogging with the new version of tunerproRT? When I datalog with it, I can watch the temperature actually start around 142C on tunerproRT and drop while my mechanical gauge is coming up. Is this a glitch in the software, or do I have the wrong temp sensor in it? I think I replaced it once a couple years ago with one I had laying around so it is possible that it's backwards. Tunerpro shows the temp leveling out around 60C (i believe) which is high enough not to mess with my closed loop enable temp, but IS low enough to mess with my TCC enable temp. I started looking at all of this because my tranny shifts really firm when cold and a little soft when Hot (TCC logic could be thrown off by a false temp reading).
Any help appreciated,
-M
Old Jul 18, 2005 | 04:44 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Yep I posted the same thing in the tunerpro forum.
I was told it's in the ECU file and not tunerpro.
Maybe try another ECU and see if it does the same. I never did try another myself.
Old Jul 18, 2005 | 04:57 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
This is a case where the ADS file has an incorrect lookup table. Is this the stock ADS file that comes with TunerPro? If so, I'll fix it. If not, you might look up the correct .ds file and correct it yourself.
Mark
Old Jul 18, 2005 | 07:55 PM
SB406's Avatar
Car: 71
Engine: 406
It's the stock .ads file that's included with tunerpro 4.0. Thanks, This verifies that I am not insane. I switched the temp sensor tonight and got the same results.
-Mike
Old Jul 19, 2005 | 07:40 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Ya that's the file I meant!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
64goatman
Sep 9, 2015 01:09 PM
