A/C clutch control $42 Code 7747 ECM
Car: 1983 G20 Chevy
Transmission: 4L60
Anyone know if the A/C clutch can be controlled with a 7747? I was reading on GM ECM and the wiring diagram has a pinout of it, but what was the A/C cutout relay used on. I want more passing power in the summer without switching off the A/C manually!!! Any help would be appreciated.
Car: check
Engine: check
Transmission: check
Normally, no, the '747 doesn't control the A/C clutch. May be able to get tricky with the EGR calibration and use that output.
The A/C input is used to change the commanded idle speed whenever the A/C clutch is enabled.
RBob.
RBob.
ambainb
Apr 25, 2016 09:21 PM
BikeFarm
Aug 11, 2015 11:35 PM
db057
Aug 11, 2015 10:11 PM
