tbi and flash chips
Old Jul 21, 2005 | 02:24 PM
11sORbust's Avatar
tbi and flash chips
I did some searching w/o any results. Do I need to ground the last 4 pins on my at29c256 to make it work with my friend's 91 TBI computer? The device offset should be 07000, right? I'm just getting a flashing ses.
thanks,
-Tim
Old Jul 21, 2005 | 03:07 PM
ben73's Avatar
I've done this in a 7747 with no trouble, and a '6870 with some issues..
Do a search on '28c64' and you'll see a post where ken73 describes how to do it.
I also recommend reading my recent thread about the chips corrupting, altho this has only happened in the 2 6870's that i have done, never a 7747....
Old Jul 21, 2005 | 10:31 PM
11sORbust's Avatar
Simple. Put a 28-pin ZIF socket on the board, use a 28C64. Connect VCC from pin 26 to pin 28, and I think it's A12 to ground - then just program 000-FFF range with your BIN. That's what I've done for now, until I get the PROMinator working.
Found it, thanks!
Old Jul 21, 2005 | 10:32 PM
11sORbust's Avatar
wait a minute, will that work for an AT29c256?
Old Jul 22, 2005 | 12:09 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Not directly, youll need to compare pins. Basically you want only the lower 4K, or lower 32,000 kbits to be accessed. Off the top of my head I dont know which pins youd need to ground. Id assume all above address pin A11.
Old Jul 22, 2005 | 07:43 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
There are several threads with that information that I found a few weeks ago when I socketed my 148.
I used the moates adapters, and if I am not mistaken he has the diagrams and some great pictures of it at his site also for some firther reference.
later
Jeremy
Old Jul 22, 2005 | 08:48 AM
11sORbust's Avatar
3.8Transam, I don't need to know how to socket the ecm. Have already socketed it. Guess I'll just try to connect VCC from pin 26 to pin 28, and A12 to ground. If that doesn't work then I'll ground out the last 4 pins. For some reason I can't find out exactly how to do it(via search).
Old Jul 22, 2005 | 09:03 AM
Car: 88 Camaro SC
Engine: SFI'd 350
All the unused address pins that address larger blocks of mem. then what the binary takes up need to be grounded.
Old Jul 22, 2005 | 01:54 PM
11sORbust's Avatar
so the unused pins + A12, A13 and A14 need grounded? I seen a resistor on the moates adapter, I think.
This is really for my friend Dave. We are trying to get a little more performance though the chip. His car is the red 91 vert that was on HPTV. Right now dave has ran a best of 13.2 . It's a stock 305 TBI with headers, exhaust and a 125 shot of nitrous. The stock T-5 and clutch is holding up quite nice. Not to bad for a heavy *** firebird.
Old Jul 22, 2005 | 08:53 PM
Car: 88 Camaro SC
Engine: SFI'd 350
That was probably for bin switching. A pull down resistor and switch to ground will provide +5 volts and 0 volts to select the banks of memory. IIRC, there are some good articles on the 'net about how the addressing works. Basically each address block that is controlled by each pin is 2^(the number of the pin). Unfortunatly, the only way to find these is by doing the dreaded and sifting through the results.
Old Jul 23, 2005 | 06:39 PM
clippjr8's Avatar
Why not just buy moates adapter for the tbi ecms to use the flash chips? Is that what you are trying to do?
92firebirdguy
Sep 1, 2016 07:53 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Ranbo108
Sep 9, 2015 12:20 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
