BIN changes when adding A/C??
Old Jul 29, 2005 | 11:22 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Anything special to do to a BIN on a 730 ECM after adding air-conditioning?
Old Jul 30, 2005 | 09:05 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I only see two things that could be tweaked if needed.
In AUJP (check location if other bin)
862A = IAC Steps added in Park (if warm) Default is 20 steps
8630 = RPM added if A/C on, default is 1 (each 1 = 12.5 RPM)
There are quite a few parameters IF the clutch is being "controlled" but I don't see any control, just sensing that the clutch is on or off.
Code:
; A/C clutch params
L837F:        .byte   0xFF      ;=255,  99.6 %TPS DISABLE THRESH               ; DRef: 0xD411
L8380:        .byte   0xFF      ;=255,  COOLANT DISABLE THRESH (218=124c)      ; DRef: 0xD41E
L8381:        .byte   0xFF      ;=255,  151c OIL DISABLE THRESH                ; DRef: 0xD42B
L8382:        .byte   0x00      ; 0 DEG C   OIL Temp HYST                      ; DRef: 0xD432
L8383:        .byte   0xFF      ; DISABLE AC IF MPH > 255                      ; DRef: 0xD43C
L8384:        .byte   0x00,0xB4 ; DISABLE IF HI MPH AFTER 18.0 SEC             ; DRef: 0xD44A
L8386:        .byte   0x1E      ; HI MPH 30 SEC BEFORE RE-ENABLE               ; DRef: 0xD45A
L8387:        .byte   0xC8      ; IF RPM > 5000 DO NOT ENAGE A/C               ; DRef: 0xD47E
; A/C IAC LEARING GAIN PARAM'S
L8388:        .byte   0x14     ; 20 STEPS DEFAULT IF Non Vol MEM FAIL         ; DRef: 0xBDCC,0xC170
L8389:        .byte   0x20     ; 32 STEPS MAX A/C LEARN                       ; DRef: 0xD4D3,0xC166
L838A:        .byte   0x0A     ; 10 STEPS MIN A/C LEARN                       ; DRef: 0xD4DA,0xC16B
L838B:        .byte   0x05     ; 5 STEPS MAX+ A/C LEARN EACH ON/OFF CYCLE     ; DRef: 0xD4E6,0xD4EB
L838C:        .byte   0x28     ; 0.04 Sec MIN RPM ERR TIME LEARN EN/DISABLE   ; DRef: 0xD4AB,0xC359
L838D:        .byte   0x80     ; MULT PK/NEUT GAIN FOR LEARN                  ; DRef: 0xD4CE
The clutch might actually be controlled in other bins, I'm not sure.
There are control bits to set the "being controlled" condition and then the on/off bits.
That's all I know of it.
Old Jul 30, 2005 | 09:14 AM
JP86SS's Avatar
Almost forgot :)
You do have to add the wire to "C9" from the A/C clutch to make the ECM work with the A/C.
Old Jul 31, 2005 | 08:47 AM
Axle/Gears: 4.1
thanks....
I ran the lead to C9; everything else seems to function ok....I guess I'll leave it alone.
Ed1LE
Sep 30, 2018 09:14 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
2012sergen11
Oct 13, 2015 07:38 PM
gord327
Oct 3, 2015 01:25 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
