7749 conversion done/speedo issue
Old Aug 2, 2005 | 03:27 PM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
I converted my 165 ecm to the 7749 last year and have noticed the speedometer at cruising speeds is about 5mph high. I have confirmed this with two different vehicles. I set the road speed constant according to this link:
http://www.speedtoys.com/~bort62/7749/Main.htm
It is originally a MAF car, and if I remember correctly, I set it at 4006 in programmer.
My question is how can I correct the 5 mph error, do I move the number above up or down, and how much?
thanks again for your help,
Mark
Old Aug 3, 2005 | 01:09 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i think you need to set it higher, try 4024 & see what you have, if it goes the wrong way, then try 3988. i don't remember just how much of a change it will make, its the trail & error method.
Old Aug 8, 2005 | 08:40 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 7749 conversion done/speedo issue
Mark
The speedometer in the dash is connected to the VSS buffer. The buffer connected to the tranny sender, and also to the ECM. changing the constant in the ECM will correct the log, but not your speedometer gauge in the dash.
I've been trying to figure this one out as well. I *think* you can wire the speedometer in the dash directly to the VSS out pin on the '730/'749 (used for cruise control) but i'd check with Bruce first. he's a lot better at the code than I am.
-- Joe
Old Aug 14, 2005 | 10:53 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
Guys,
thanks for the info. I will reply to this to see if we can get anymore hits from the experts.
Mark
Old Aug 14, 2005 | 06:10 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'm doing a vaguely similar swap right now and I'm running pin 11 (brn) of my DRAC (VSS buffer) to pin C6 of my 7730.
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
