BLM chart in TunerPro?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Curious if there is any way to chart the BLMs in TunerPro, ala WinALDL?
Car: 1983 G20 Chevy
Transmission: 4L60
Why when WINALDL will average all the BLMs and even give you wide and narrow correction numbers.
Car: 91 Red Sled
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Bingo....I'm really spoiled with the WINALDL charts.
I've made an excell file that will take a log file and make charts for you, but my laptop is so slow it won't crunch the numbers in any reasonable time.....I made this file to crunch the numbers from my zeitronix WB which logs at 80 frames a second.
Any one listening....we want easy to read charts in Tunerpro
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by JPrevost
Maybe because Winaldl is only 160baud.
Actually, I'm thinking more along the lines of my '302 ecu will not do BLM logs in WinALDL.
Whoa... can someone give me an idea of how to build a chart like that in Excel?
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I'm going to be re-writing the ALDL engine in TunerPro over the next 2 or 3 months (have 1 or 2 other things to finish up first).
This will be one of the many big changes.
Glad you're using TunerPro!
BumpaD82
Feb 26, 2016 02:57 PM
Gladd to see customer support like this, almost brings a tear to my eye.
