Tunerpro
Old Aug 14, 2005 | 12:41 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Tunerpro
I have tunercat and just downloaded Tunerpro.
When in Tunerpro some of the constant values do
not match what I have entered in the tunercat bin.
where is tunerpro finding it's values if I'am using
the same bin I used in Tunercat
Old Aug 14, 2005 | 08:21 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Please sure would like to know
Old Aug 14, 2005 | 09:55 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Post your ECM#, mask ID and Tunerpro ecu/xdf, someone may be able to help you out, just need some more info.
Old Aug 15, 2005 | 12:22 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
This generally means the math defined in the XDF doesn't match the match defined in the TDF. If the differences are minor, it's likely nothing to worry about.
If data points are way off, then I'd investigate further (via a hack if available).
Old Aug 15, 2005 | 05:22 PM
DM91RS's Avatar
Car: 91 RS
I've ran across the same thing in the spark and VE tables using the xdf for the 8746. The values are different or are located in the wrong cells in the charts compared with tunercat.
DM
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
