Heated O2's are overrated...
Old Aug 11, 2005 | 12:47 AM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
So my AFS-74 decided to stop working. I then attempted to revive it with a propane torch, didn't work. I was pressed for time so I got the stock 1-wire from the zone for $22. Got everything installed, fired it up and took off down the road. Within 1 mile the O2 started pinging perfectly and went into closed loop. It seemed like it was reacting a lot faster than the heated O2 when it was new.
Another thing that motivated the 1 wire was that I tested out the heating element. I hooked direct battery voltage to the O2. I was holding it and didn't feel a thing, just cold metal. After about 1 min I put it to my cheek, ahh, its luke warm....DumDaDum....its still luke warm. WTF!?!?! 500 degrees my butt
Oh, I am running Hedmen LTs and the bung is in the extender about 2 in from the collector.
Old Aug 11, 2005 | 03:04 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Probably got a bad one from the get go.
I wired in my heated o2, also a AFS74 and havent had any bad exeperiences, unless you count going into closed loop faster and much more consisitent :-)
Watch your o2 crosscounts at a prolonged idle and/or when the temp drops.....................
later
Jeremy
Old Aug 11, 2005 | 08:10 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I dont know if youll get a boatload of heat out of a heated NB O2. Its not like one of the controlled WB-O2s where it glows a nice orange at all times. Basically the heating element is there to dump some extra heat into the O2 to keep it warm and clean. Even after 100,000 miles the O2 is still nice and clean.
Old Aug 11, 2005 | 11:51 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Heated O2's are overrated...
Originally posted by WhiteHawk
[B Within 1 mile the O2 started pinging perfectly and went into closed loop. It seemed like it was reacting a lot faster than the heated O2 when it was new. [/B]
The 3wire for my TBI G20 gets hot enough in the header to get an accurate signal about 20 seconds even at idle after a COLD start. It goes into closed loop at 30 seconds and runs fine even when ice cold.
Your car can waste a substantial amount of gas in-town driving with short little trips and pollute alot more. The main reasons OEMs switched to them.
My old 1 wire in the header collector (full lenght headers) took about 1 mile to warm up as well. It worked fine as long as it was under load. In cooler weather when I stopped and idled it would cool enough to revert to open loop and give an O2 sensor code.
Old Aug 11, 2005 | 12:59 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Yeah, I guess in the winter it will be a different story. I need to some how connect the 3 pin weather pack back onto the O2 so I can warranty it
Old Aug 12, 2005 | 03:46 AM
3.8TransAM's Avatar
Oh yes, u mentioned the zone and 02 which means Bosch. they have known grounding issues and also are not correctly calibrated to the GM fueling PID. Do a search and you will find lots more info on them as well.
If your going to run a 1 wire then get the Delco. If u shop around and try the turbo buick vendors or bulk Delco suppliers, u can get them for 20$ a piece :-) Or like 22$ a piece and 3 for $60.
later
Jeremy
Old Aug 12, 2005 | 12:58 PM
WhiteHawk's Avatar
Car: 1991 Firebird
later
Jeremy
I am going to warrenty that 3 wire I had. Although I need to get one of those weather packs so I don't have to hack them any more.
Old Aug 12, 2005 | 02:58 PM
3.8TransAM's Avatar
I got my connector new thru a CarQuest store.
U can walk a junkyard and yank them from 93-95 4.3 blazer/s10 and GMC siblings thou. Get u a free connector ot two.
There is a list somewhere posted here that has all the apps, also I believe if u search ebay for afs74 it will net u the listing as well.
later
Jeremy
Old Aug 12, 2005 | 03:04 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I got mine at Pep Girlz..... in the "HELP" section.
Old Aug 14, 2005 | 07:54 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
If you look here at post #14 it has a list of applications that the AFS-74 was used on. Also has a some info on the BOSCH NB sensors.
https://www.thirdgen.org/techbb2/sho...hreadid=263519
