Not running elec fans on 730...
Old Aug 14, 2005 | 06:19 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'm swapping to a 730 ECM in my '89 Astro which has a mechanical fan with a thermal clutch. Will leaving pins D12 (A/C press fan sw input) and E8 (coolant fan control) blank affect the ECM?
I see at $8019 bit 5 has something to do with a fan input...
Old Aug 14, 2005 | 11:37 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I don't run electric fans and it hasn't done anything to mine.
A/C input signals to raise the idle and a few other IAC related items. (I do have that connected cuz I have the A/C)
Fan request input just enables the fan output from what I'm seeing. The bit 5 is to select a normally open or normally closed switch on the input.
Wouldn't worry about it.
Old Jul 1, 2012 | 11:14 AM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: Not running elec fans on 730...
A/C input signals to raise the idle and a few other IAC related items. (I do have that connected cuz I have the A/C) Fan request input just enables the fan output from what I'm seeing. The bit 5 is to select a normally open or normally closed switch on the input.
On the question of "normally open" or closed. I have mechanical fans as well. I've been attempting to test the fan circuit for correct operation before I actually swap. Test LED's hooked up to pins E8 and F8 are on at all times when when in "key on". To energize the circuit properly, do I want bit 5 to be selected with a check mark in the box or left empty ?
Dave Buchholz
Rochester NY
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
