WBO2 reads rich but BLM's high
Old Jun 29, 2012 | 06:25 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
I am tuning a new minirammed 383 with a fairly aggressive cam for street (236/242@.050, .560 lift, rhoads v-max lifters). I am using TunerPro RT, an arap bin as a starting point, and a widband to verify tune. This is a completely different tune than my last superrammed engine. I have the car running well with near perfect driveability but I am still having an issue that I can't quite figure out. At certain points, especially low cruise, the WB averages about 13.9:1 rich but my BLM's are pegged high showing a perceived lean condition. The BLMs never ever drop below 128. I am thinking I should focus on the Rich/Lean Threshold vs. Airflow table and lower the voltage readings, which I have done somewhat to achieve a WB reading of 14.6:1 for idle but the persistent high BLM's are confounding. I just replaced the stock NBO2 so that should not be the issue. Am I barking up the right tree or perhaps someone who has dealt with this issue before could steer me in the right direction. Maybe MAF Scalar? Thanks.
Old Jul 2, 2012 | 02:24 PM
cormyr's Avatar
Engine: 383 miniram
Re: WBO2 reads rich but BLM's high
yeah that's what i thought. man, i miss grumpy...
Old Jul 2, 2012 | 02:53 PM
Ronny's Avatar
Low cruise as in low load cruise? If so there may be reversion due to your cam and lack of vacuum. ECU may be adding gas unnecessarily hence the high BLM. In fact may be adding more than BLM can report. I trust the WB being accurrate.
What does the BLM look like under load?
Try running OL for a test to see how it runs without BLM feedback in that same area of low cruise load?
Azrael91966669
25
Jun 20, 2017 04:04 AM
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
tmellott89
Aug 16, 2015 02:58 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
