T56 swap VSS/ECM question
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I am using Tunerpro v5 with $8d mask on a 7730 ecm with s_aujp_v41026 bin. I just finished a T56 swap and have an Autometer electronic programmable speedo. Calibrating the speedometer is fairly simple but my question is how do I tell the ecm how fast the vehicle is going? I noticed a vss pulses scalar at hex address 0x15 in Tunerpro and I'm pretty sure that needs to be changed however I'm not sure how many ppm the T56 vss is. I did a search and all I could find was the vss puts out 17 pulses per revolution. How is that converted to pulse per mile with 26" tire and 3.73 gears?
Car: 1985 IROC-Z28
Engine: LB9
Re: T56 swap VSS/ECM question
if 17 PPR is correct....
17 * 3.73 = 63.41
26" tire makes 775.58 revolutions per mile.
63.41 * 775.58
49,179.5 pulses per mile.
17 * 3.73 = 63.41
63.41 * 775.58
Car: 1985 IROC-Z28
Engine: LB9
correct. that will give the ECM the correct value to work with to create an accurate MPH value. since you're not using the 4K PPM signal from the ECM for the speedo, then you don't need to mess with the divisor stuff either.
Awesome stuff thx saar. I have an sgi 5b box but didnt feel like running additional wiring.
Car: 1985 IROC-Z28
Engine: LB9
should you decide to swap tire sizes or the diff, i use this calculator all the time.
http://www.discounttiredirect.com/di...foTireMath.jsp
just multiply PPR by diff ratio by revolutions per mile.
1992 Trans Am
Aug 8, 2015 08:16 PM
