What to do for a ECM?
Old Aug 22, 2005 | 05:05 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
The block is from an 89 police intercepter
stock forged crank, stock rods, forged pistons,
heads stock slight work (new guides and valve job) along with runner work done on all police engines,
Comp Cams cam kit 212/218 @.50 (i think - looking for the cam card),
roller tiped rockers.
Ok so my car is an 88 ta with tbi want to keep it tbi. dont have the prom burning equipment yet loking into buying it.
So i want to know what i should do to beable to get it to run right not perfectly tuned but good enough to break the engine in. should i update my ecm or do you think the 88 ecm is good enough?
Old Aug 22, 2005 | 05:14 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It sounds like you are just starting out so I would stick with the basics and learn on your exixting ECM. Messing with wiring, learning to ECM tune with a new engine is like jumping into a fire in my opinion.
Some people break-in engines with a carb to be on the safe side. It depends on how good you are.
Old Aug 22, 2005 | 05:32 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
noob question
my ecm is the 747? and what bin do i have dont want to pull me ecm if i dont have to
i found this on the boards it this my setup?
LO3=
C3
8746 ecm
2732a eprom
$61 mask
160 Baud
Old Aug 22, 2005 | 05:43 PM
junkcltr's Avatar
Engine: 3xx ci tubo
You have to, pull the ECM lid and check. Others can only guess at what is in the ECM. Maybe someone changed it before you. Who knows what engine was orig. in the car. Part of learning how to burn PROMs is checking what ECM and PROM you have. Next step is figuring out what equip to get.
What is runner work done on all police engines??
J
Old Aug 22, 2005 | 06:04 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
slight porting is done on all police engines
for an lo5 they dont come with swirl port heads either
Old Aug 22, 2005 | 06:18 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
its stock i know the previos owner. i dont want to take it out yet because i sprained my ankle over the weekend
Old Aug 22, 2005 | 06:30 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
thanks for your help i guess ill be back later when i find out what i have in the car
Old Aug 22, 2005 | 07:34 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
im pretty sure this is my ecm right? 1228063
Old Aug 22, 2005 | 10:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its an 8063. Theres a decent ammount of info out there for it so you dont have to upgrade.
Old Aug 22, 2005 | 10:23 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
thanks that will about cover it fir now
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Only difference in the LO5 caprice engine vs. a truck or van engine is a L-98 roller cam. It still has unported 193 swirl ports on it, unless someone has added reworked 083s. The other differences are in the chip, injectors, and exhaust.
Don't believe me? Pop the valve cover off any "police interceptor" engine and you will find 193's that are no different than the ones on trucks. If you happen to find some other number it is because someone changed them out or swapped engines.
The only TBI 350s that I know came with forged pistons and crank are the HD 350s in 3/4 ton + trucks.
That being said you will still like the torque gain of the 350, especially with a cam.
Change to police 350 injectors, use your camaro TBI ecm, use the caprice 350 bin file, and tweak away. Your main changes will be in the VE1, VE3, and timing tables. Command air/fuel ratios could use some help too.
Old Aug 22, 2005 | 10:58 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Police chip wont work in the 8063, although you could pilfer all the important stuff from it and drop it in the 8063's calibration.
Old Aug 22, 2005 | 11:20 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Duh, I'm thinking 8746. You are right though the biggies are VE1, VE2, Spark, BPW constant.
Old Aug 23, 2005 | 12:47 AM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
Sorry i didnt know if the heads are from the same car but they cave a bit of porting with a new valve job. new guides (machine shop) and ground the seats (myself), new valves manley swirl polish. full comp cam kit 212/218 @ .50 with crane 1.6 roller tipped rockers. kieth black forges pistons bored 30, stock rods (cast-next rebuild ), stock forged crank.
I want a holley tbi intake w/egr, holley or a 454 tbi, hok-2055, hi-flo cat, flomaster cat back.
While im working to get that im looking into working on the ecm configuration.
after im up and about in few days ill look into confirming what heads i have, just learned what i hae in the car im driving (swirl port heads man thats a shame they did this to these cars)
thanks for helping me clear that up
Old Aug 23, 2005 | 01:10 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I personally like the swirl ports. They are in the same league stock for stock as the TPI heads. I have seen TBI heads swapped for TPI heads and no appreciable power gained to justify the swap. Port some 081 or 083s and you will see the gain. Simply ditching the swirls for a stock TPI head doesn't help much.
You really don't need anything special for the intake or the TBI. I used the stock size TBI and stock intake and still made 270+ RWHP on my 355 TBI.
Old Aug 23, 2005 | 01:22 AM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
storck injectors and stock ecm?
Old Aug 23, 2005 | 01:25 AM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
im going to but installing the engine this fall with the full exhaust
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
