1228746 help please im very new like one day
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
okay so heres my last two posts from the tbi forums i figured id post here too since its diy prom specific and i havent gotten an answer on this one there yet...im just wanting to start messing w/ a stock bin for my car before i get a programmer so im not so dumbfounded and w/ out a car when the time comes....if someone could please direct me to a proven .xdf and .bin for my prom id be much appreciative. right now im using tunner pro till i get the cash for the programmer and tunner cat. thanx.
https://www.thirdgen.org/techbb2/sho...hlight=1228746
see this is the link to the post w/ the xdf file on moates but it just opens as a web page and now i got the program and a .bin all i need is the xdf to start fooling around
k i think i figured out how to dl as a .xdf i had to use wellget a dl manager but when i load that and open the bin and click somethin like egr it just comes up w/ a box that has a place to click "set" then a save and cancel button??? i understand if these dumb questions r pissin u guys off but i just wanna start to try and tackle some stuff other wise i will be so dumbfounded when i comes time to actually burn one ill have no car for along time and it will be soooo frustrating.
Car: check
Engine: check
Transmission: check
. . .and open the bin and click somethin like egr it just comes up w/ a box that has a place to click "set" then a save and cancel button???
If you can do a screen shot and post a small image it would be helpful. It sounds like you opened a MALF flags bit for enabling/disabling the EGR diagnostics reporting. If this is the case then setting the bit enables EGR malfunctions to set a code and the SES light. If the box is unchecked then EGR malfunctions will not be reported.
Try opening the Main SA table. That should make a little more sense. There wil be a MAP axis (load) and an RPM axis. At each intersect will be a SA value. That SA value will be the base SA for the engine at that load and speed.
RBob.
RBob.
Engine: 305 tbi l03
k ill have to find a program for a screen shot i had one but deleted it ill do that tonight when i get home cause im at work at the moment but everything else u said was still very confusing cause as i said that was the first day i had messed w/ any of it and the very first time i actually dl and opened the program. but ill look at it tonight again when i get home. but to post a pic dont i have to have a site hosting it first any idea of a site to host it cause ive never messed w/ posting a pic on here before.
Engine: 305 tbi l03
okay here is the screen shot i was talkin about for when i load that .xdf and a supposedly stock bin to learn to play w/....this is what happens when i click egr under flags
Engine: 305 tbi l03
now i know how to upload images and i have a screen shot trial so let me know if u need any more to look at to see if i got the right thing. thanx guys like i said im just starting and am just tryin to fool around w/ bins b4 i get a programmer so i wont be so in over my head when the time comes everyone has to start somewhere
Car: check
Engine: check
Transmission: check
Pic shows 'EGR type.' Typically this isn't something that is changed. On the other side of the coin, I don't know what defines an 'EGR type.' A quick (about 30seconds) look at the code, it may be controlling the ECM output being high or low to activate the EGR soleniod.
HTH's,
RBob.
HTH's,
RBob.
Engine: 305 tbi l03
oh okay i was just trying to start w/ the easy stuff like egr and smog disable and changing the fan on and off temp and things like that...what should i be messin w/ then?
Engine: 305 tbi l03
so i just need to change the egr on off temps then? so that it never comes on...i also heard somewhere on the forums that if u set it too high it may cause problems w/ somethin i cant exactly remember the context w/ all the articles ive been reading on this but does this ring a bell to anyone?
Engine: 305 tbi l03
im finding like eight diff. constants dealing w/ egr temp, iac, speed, and map (all on/off settings) do i need to change all these when i really get started (right now just practicing dont have a tuner) to disable my egr all this is looking a lil confusing since i dont even know what the map does or how it opperates in the prom sorry for the questions that r obvious to many of you but im just affraid that you guys will think my questions too basic or dumb if i do get the programmer and i will be stuck w/ it not knowin the sligtlest thing about tunning even though ive read many stickies and faqs. cause most r specific to tpi and i have the tbi ecm and prom thanks and sorry again for askin the basics.
RedLeader289
May 28, 2019 01:47 PM
