Fan Control Using Air Divert Output
Old Aug 23, 2005 | 01:05 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
I have a 165 ecm using the Arap bin and would like to use the ECM and the (unused) air divert output to control my cooling fan. I use a 180 deg. thermostat and bulky adjustable thermo switch for fan control..this works but looks awful.
I can follow the wire logic but I'm not sure if there are other ECM routines that would affect engine operation? Both AIR and EGR hardware have been removed.
Can I use the AIR divert output to the fan relay without other changes to the Arap bin?
Old Aug 23, 2005 | 07:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The stock '165 w/ARAP supports a fan. Pin C1.
RBob.
Old Aug 23, 2005 | 08:02 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Do a search for Glenn's post about using the ECM to control both cooling fans. All you need to do is swap a pin....
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
lakeffect2
Aug 23, 2015 08:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
